Ana içeriğe geç
1.5 Core Solo, 1.66 or 1.83 Core Duo, or 1.83 or 2 GHz Core 2 Duo processor. This covers the first Intel-based Mac Mini models from Early 2006 to Mid 2007.
Replace Optical Drive with SSD
Is it possible to replace the optical drive in a mac mini A1176 with an SSD? The interface of the optical drive is listed as pata, but looks to be a 50-pin connector supplying power as well. Whatever that interface is, I'm looking for a sata ribbon adaptor for it.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
The left hand column on this link to OWC shows upgrades for your machine including a SSD drive: http://eshop.macsales.com/shop/mac-mini/
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
mayer,
the ssd upgrade on that link appears to replace the existing hd in the mini. I'm looking to replace the optical drive with another ssd.
tarafından
Yorum Ekle
You are correct, it uses a PATA connection, and in order to use a modern (half decent) drive, you would need to convert the connection from a PATA to a SATA drive. Of course these are still IDE connections, just different interfaces given the project.
A convertor like this would work: http://firmtek.stores.yahoo.net/seritek1...
The issue is then compatibility. To be honest, I know that Apple has never truly supported PATA to SATA connections, but that doesn't mean that it won't work.
Puan 0
1 Yorum:
knowitall,
thanks. ive ordered a similar circuit card based adapter from amazon, waiting for it to arrive. im hoping for a cable solution, but no luck so far. goal is to fit the whole bundle back within the mac mini case.
tarafından
Yorum Ekle
Yanıtını ekle
paul sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 37
Her zaman: 4,869
