Will not drain at end of cycle
My Bosh dishwasher has been a problem and will not drain at end of cycle I cleared all lines, not solved then replaced the pump, not solved then replaced the pressure sensor, not solved them replaced the motherboard, not solved detached the long part f the drain hose and redirected the short half to drain into a pail, bravo worked then raised the pail and stopped draining again. Seems that any back pressure causes a E25 and will not drain. Can anyone help?
Bu iyi bir soru mu?
3 Yorum
Has it ever worked correctly? Have you changed your disposal lately?
mayer tarafından
Worked fine for 4 years and we have no garbage disposal. Thanks for looking in.
David tarafından
Have you checked the float at the bottom of the dishwasher make sure nothing is under it?
Jessica tarafından
