Floppy diskette seek failure? F1 continue. As far as I can go.
I can turn off and another startup. That is it. .?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
A “floppy diskette seek failure” means that your computer is trying to boot from a floppy disk instead of your hard drive. For your computer to be used, it must boot from your hard drive.
In order to make your computer boot from your hard drive, you must enter a program called BIOS on your computer. The way to enter BIOS is to press F2 repeatedly right after you press the power button. That will get you to your BIOS. You can then find the BIOS setting that will make your computer boot from your hard drive.
Here is a link to a video on YouTube that explains this in more detail:
Bu yanıt yardımcı oldu mu?
I will check this out. Thank you
A technician suggested I install windows 10 on the new hard drive.?.? Sounds correct. Will try.
Installing 10 will cause 1 or 2 hours to do a max 10 min job? Listen to your first answer
Son 24 Saat: 8
Son 7 gün: 42
Son 30 gün: 185
Her zaman: 19,714
2 Yorum
Gordon Stoa you are not giving us a lot of information to work with . At minimum we need to know the make and model of your computer. what is it doing? What have you checked? Does it have a HDD? Have you checked the BIOS? If you want us to help you fixing it you need to help us helping you.
oldturkey03 tarafından
Sorry I am learning ifixit. Looks like a great helper. I installed new hard drive. Maybe a mistake I keep getting the same message floppy diskette see failure. F1 to continue ?.? I am stuck and want learn. So I can help.
Gordon Stoa tarafından
