Ana içeriğe geç
Canon PIXMA MG6660 hepsi bir arada fotoğraf mürekkep püskürtmeli yazıcı için onarım bilgileri.
Printer Wont turn on
Plugged and Unplugged after recieving error code B203, and after leaving it unplugged overnight, the Printer WILL NOT TURN ON :( any suggestions as to what to do.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
3 Yorum:
This happened to my MG6650. I didn’t use it for a month and when I turned it on it initially showed this error and I wouldn’t let me do anything. Well I tricked it and it started to print but turned off after a second. After that it would not turn on anymore.
tarafından
did you change the power code and check, did you try with a different power outlet
tarafından
@shiham Well I tried a different power outlet but didn‘t change the cord. The cable should be fine.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
if no power try replacing the power cable,
if it is error B203 try the below link steps,
Sometimes, the Error Code B203 indicates that there is an empty ink cartridge. Now, if your Canon printer is running on two different kinds of ink cartridges. Then, it might possible that one of them is empty and that is creating this error on your system.
LINK
or tey doing a hard reset : LINK
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
cindi_kofalk sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 16
Her zaman: 4,975
