Ana içeriğe geç
The fifth generation van had debuted at the 2007 North American International Auto Show with exterior styling by Ralph Gilles.
Replaced belt now I have water coming out.
Serpentine belt shredded it self. I was able to replaced it myself. But now I have water coming out all over the ground. It wasn’t leaking before I replaced the belt. Any idea what it could be?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
Did you remove the water pump or loosen it while putting the new belt on?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
You need to prove where the water is coming from, it happens that when you replace a belt that the extra good tension is on the water pump, the bearing shaft seal will start to leak but make sure where the leak is coming from, fix that and your good, did you accidently put pressure on a hose and tear the hose a little?
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Greg Thompson sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 81
