Ana içeriğe geç
a7R II (model no. ILCE‑7RM2), Sony'nin 2015 yılında piyasaya sürdüğü tam kare, aynasız, değiştirilebilir lensli fotoğraf makinesidir.
Menu scrolling through itself like crazy
My Sony A7S Mark 2 is moving the menu by it self please how do I fix this?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
5 Yorum
hi, i have the same problem with my Sony A7ii. Menus switching on its own and sometimes goes back to normal then switching and scrolls again.
Did you already FIX yours??
Thank you :)
tarafından
Same problem. Any help?
tarafından
Me too. Anyone sort it?
tarafından
Very late reply. Got mine fixed at the nearest camera repair shop for USD65.
They say this is a common problem with Sony A7II after sometime...
tarafından
Hi. Did they say what the problem was that fixed the camera? 65$ is pretty affordable. Thanks
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hey, Shakily_17
The issue could be that you need to replace the buttons, but it's likely that a ribbon cable isn't fully connected or it is damaged. This issue can be found in other devices such as the Sony Dualshock 3 and the Asus Zenbook.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Sounds like a "Stuck Button" Problem. Common with most devices that you use the buttons, when they aren't cleaned they can stick. Even if the "External Buttons", or the button layovers, are cleaned, the internal buttons may be dirty. Try cleaning the buttons with Isopropyl Alcohol, and a soft electronics towel. If that doesn't work, check the cables and clean the internal buttons and cables if necessary.
Puan 1
Yorum Ekle
Yanıtını ekle
shaikly_17 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 50
Her zaman: 1,737
