Ana içeriğe geç
Fifth generation of iPad, released in March 2017. Available in Wi-Fi and LTE with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A9 processor.
174 Soru Tümünü görüntüle
Accidentally ripped home button flex cable opening iPad.
I was changing the screen for a coworker on an iPad Air 5. I’ve done a screen replacement twice for them but this time I accidentally forgot to disconnect the home button ribbon and yup it got sliced in half.
Does TouchID stop working on iPad if you use a new cable? Is there a way to splice them?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
you may be able to splice the existing cable to a replacement. however the replacement would most likely need to be an OEM one from another broken device or such, and would require microsoldering equipment/experience.
a replacement home button may not have touch id but it’ll still work fine as a home button
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
Yes I’m facing the same problem. I’m trying to source another cable to splice two together to make one. I’m under no illusion I know it’s very difficult.
tarafından
Yorum Ekle
Very simple answer to this question
No you cannot splice them and you lose you fingerprint ID
It may be possible to connect the broken cable together but you would want to be very good a microsoldering
Even at that is it worth the time doing it
Puan 2
Yorum Ekle
Yanıtını ekle
Baldemar Orozco sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 22
Her zaman: 1,567
