Ana içeriğe geç
1.5 Core Solo, 1.66 or 1.83 Core Duo, or 1.83 or 2 GHz Core 2 Duo processor. This covers the first Intel-based Mac Mini models from Early 2006 to Mid 2007.
Would T7300 (800MHz FSB) work as drop in CPU replacement?
I have the 1,83GHz Core Duo version with 677MHz FSB. Can't locate T7200/T7400 (known to work as C2D upgrades) - but can get T7300 which has 800MHz FSB.
Will T7300 down-clock to match motherboard/RAM?
Perhaps this MacMini will make it to OS X Lion.. :-)
Thanks in advance
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
its hard to say. the 956 chip set is limited to 667mhz fsb but in other mobos and chip sets i have seen it under clock the fsb and work just fine.
it is hard to tell if the mini will do it. i am getting a mini soon and will be trying hte same thing.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
The T 7300 intel processor was used in just one iMac. Most are for mobil machines and I think have the P socket. I don't have time to check right now but I believe your machine uses a M socket. Check here: http://en.wikipedia.org/wiki/List_of_Int...
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
I don't know how old (or new) this post is. It's common knowledge that the T 7600 will work. It is available on eBay for about $100.00 US.
Update
just received your note:
Here are two different blogs which discuss the T 7600 and other compatible ones. And an eBay link. I'm considering doing the same so I can operate Lion/Lion Server on my Mini. Good luck!
http://www.123macmini.com/forums/viewtop...
http://forums.macrumors.com/showthread.p...
http://www.ebay.com/sch/i.html?_nkw=t760...
Puan 1
Yorum Ekle
Yanıtını ekle
Gerard Byrne sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 2,552
