Ana içeriğe geç
4 Kasım 2017'de satışa sunulmuştur. Model A1865, A1901. GSM ya da CDMA olarak 64 ya da 256 GB kapasitelerinde, Gümüş ya da Uzay Grisi renklerinde satılır. ("iPhone 10" olarak da telaffuz edilir.)
1199 Soru Tümünü görüntüle
iPhone X boot loop issue
I am a technician with the skills and access to microsoldering equipment. I am trying to avoid separating the two board layers if possible because it is a pain to get back together and may not be necessary. The phone is doing a 3 second boot loop. I have tried to turn it on with only essential components plugged and I have frankensteined new hardware in order to rule out hardware issues. It is recognized by iTunes. I attempted every reset possible, and none of them work. When attempting to restore the iPhone through iTunes, the restore stops right after extracting software (likely because of whatever is causing the boot loop). On the board level, are there any pads I can test in order to confirm that I need to split the boards? Does anyone have a clue what might be causing the issue? On my USB detector, the output reads a stagnant 0.47A @ 5.09V
Bu iyi bir soru mu?
Puan 1
1 Yorum
Mine does exactly the same thing on trying to restore
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Check around nand for shorts. But the problem could be the solder joints.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Try a genuine replacement charge port assembly. They can cause reboots when they go faulty.
Puan 1
Yorum Ekle
Yanıtını ekle
Batteries Bulbs sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 118
