Ana içeriğe geç
If I wanted to install a thunderbolt port, how would I do so?
I want to remove a USB port and instead install a thunderbolt port with a Thunderbolt chip from HP as well. I wanted to do this from the I/O, and remove the USB 2.0 slot.
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
That model laptop already has two USB 3.1 ports according to HP’s web site, which support Thunderbolt 2 speeds via a dongle, as long as the data is only moving one direction.
As far as replacing the USB 2.0 port directly on the system board with a different port, that’s pretty much impossible because the connector from the board to the I/O port is pretty different between USB 2.0 and Thunderbolt 2, and Thunderbolt 2 and 3 also need a controller chip in order to function properly. Also, Thunderbolt runs through PCI lanes and the I/O board is probably not assigned any at all, because USB handles data differently.
Thunderbolt in general is kind of a mess, and unfortunately while it’s useful and fast there really isn’t a way to add it to a laptop that doesn’t already have it without replacing the system board and hoping everything still fits.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
But what if I want to change usb-c for thunderbolt 3?
tarafından
You'd need a way to assign PCI lanes to the Thunderbolt controller, which would unfortunately pretty much mean a full motherboard/BIOS redesign. Just not really something you can do, unfortunately, even though the connector is the same. It's that dang controller chip Thunderbolt needs.
tarafından
Yorum Ekle
Yanıtını ekle
Tyrell Compton sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 28
Her zaman: 1,115
