Ana içeriğe geç
The Hoover LiNX is a cordless vacuum cleaner. The vacuum uses interchangeable fade-free lithium-ion batteries that allows this device to be used everywhere and on multiple floor types. The Hoover LiNX uses Hoovers WindTunnel® 3 Technology which uses three channels for suction to suck up debris.
4 Soru Tümünü görüntüle
The brush rotates intermitantly, seems as if there is a loose wire
The suction is fine but, the roller brush rotates intermittently. It re-engages when I bounce the LiNX but not always when I turn it on and off. There seems to be a loose wire or connection somewhere. Any suggestions will be most welcome.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 4
Yorum Ekle
1 Cevap
Filtre ölçütü:
I had a similar problem. However, my wire was severed. I had to open up the head unit and resolder it back together. Since that fix I have not had any issues.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
Was the problem intermitent? Weems a severed wire would make it not work at all?
tarafından
Yes mine works intermittent too, not sure what is causing this.
tarafından
Yorum Ekle
Yanıtını ekle
Alan McDonald sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 15
Her zaman: 460
