Ana içeriğe geç
KitchenAid's Artisan Series 5 Quart Tilt-Head Stand Mixer model number KSM150PSER. All models starting with KSM150PS are the same device just different colors.
Meat Grinder Attachment Won't Grind...It Sticks
While grinding meat using the grinder attachment, the sound of the motor has changed and then the grinder stops. I suspect it needs to be cleaned. What is the recommended method and materials to do this?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum
The problem is not with the attachment. It is in the Kitchen Aid mixer.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
While the change in motor noise is most likely a motor fault, do examine the grinder itself. If the front ring is too tight, the mixer will grind (pun alert) to a halt.
If the grinder is adjusted properly, the motor’s worm-follower gear is the next thing to look at. It is designed to fail and save the motor from burning out.
The Service Manual can be found at:
++http://www.kitchenaidparts.eu/documents/...
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Chuck Pelto sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 10
Her zaman: 2,045
