Ana içeriğe geç
Apple Magic Mouse, Apple Inc. tarafından üretilen ve satılan bir çoklu dokunmatik faredir. İlk kez 20 Ekim 2009 tarihinde duyurulmuş ve satışa sunulmuştur.
Can I replace the laser bulb?
Everything is working on my Magic Mouse but the laser sensor, itself. I can gesture, scroll, right click, double-click to select a word. BUT the laser no longer comes on, so I can't move the pointer. Can I replace the laser?
Bu iyi bir soru mu?
Puan 8
1 Yorum
can you explain me in detail that how you fixed it kaath9?
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
I've never seen this part fail. I would suspect a failed solder joint. Of course if it is less than a year old, get a warranty replacement from Apple. If not, I'd tear it down and see if I could spot the problem. Here's the teardown: Magic Mouse Teardown
Bu yanıt yardımcı oldu mu?
Puan 4
5 Yorum:
You're right mayer, mine wasn't working well, only clicks and movements but no cursor moving. Once opened, I've heater the laser pinouts with a soldering iron and it's working well now. The problem now is to fix the batteries plugs. In order to disassemble properly, we need to cut 2 plastic pieces who maintain the metallic rounded batteries plugs on the frame
tarafından
Can I solder without removing the capacitive sensor ribbon nor the battery case? @kospeia Did you achieve to do it?
tarafından
What Part of the mouse do you solder once you open it up?
tarafından
Asher Solder the place where you no longer have continuity.
tarafından
Thanks Mayer
tarafından
Yorum Ekle
I had the same problem! After several attempts, I tried to push the lens with a pencil eraser, now it works fine
Puan 0
3 Yorum:
It makes me laugh, this is ifixit.
tarafından
Hello fabrizio,
Did you just press it up, without opening the mouse?
Thanks in advance!
tarafından
Hello Antonio, yes, you can do it without opening..... but ... the operation did not last much for me :-(
I think at this point that you have to open it and solder contacts with a soldering iron!
tarafından
Yorum Ekle
Yanıtını ekle
kaath9 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 28
Her zaman: 17,580
