Ana içeriğe geç
The Dremel 4000 is a variable speed rotary device. It is compatible with with all Dremel rotary accessories.
Dramel 4300 rotary tool 120v
I placed my tool into a 220v socket yet it takes in 120v and it stop working any help on how to replace the Electrical Assembly Replacement unit for the dramel 4300 Rotary tool and where i can find an Electrical Assembly Replacement for the Dramel Rotary Tool
i have used the picture for the Dramel 4000 becouse the admin seems not to have Dramel 4300 in the drop down
thank you
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
You probably burned out the motor when you plugged it into a 240V outlet How did you manage to do that? normally the plugs are not compatible.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Could be in a foreign country that uses universal outlets? I am an American Vet living in the Philippines and I changed some of my outlets to accepts everything, I also have a commercial grade transformer for 100 and 120 while local voltage is 220. locally they do not have a third ground connector and also do not have the wide spade (polorized) connector as the USA does. Not sure how simple the dremel plug may be? I also believe that there could be 220 in the USA but the OP is saying 240 so I believe this is not in the USA.......
I recommend to open the tool, see if there is a possible fuse, if not, then replace the entire unit, by the time you get a replacement part, if available, and your time to change it, you will not save much money in the end.
tarafından
Yorum Ekle
Yanıtını ekle
Brighton Albert sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 915
