Ana içeriğe geç
The larger version of Samsung's flagship phone, the Galaxy S8+. Released in April 2017.
What is the gold film under the glass?
So I am trying to do an glass only repair of my S8 Plus. I have taken it apart and removed the glass from the mid frame. Under the glass is a gold film with a ribbon at the bottom. Is this the digitizer? Do I remove the film? I have the glass only do I need to get a glass with digitizer or a whole new LCD? The glass I removed looked tinted the glass I have is clear and it looks just wrong it I put if over the gold film
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
1 Yorum
I have this question too. I'm attaching a picture below (not an Answer). Any help would be appreciated. Thanks!
tarafından
Yorum Ekle
7 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I have this question too, so I’ll provide additional information to what the OP shared.
The thin gold film appears to be directly under the glass (my glass is also tinted). It’s adhered to an underlying darker glass (presumably the LCD). In the pictures I’ve attached, you can see the gold film separated from the top glass, but still attached tot he bottom glass. The bottom glass that’s still on the phone looks similar to the picture @iyoungstai posted and called the LCD. In fact, if you look on the top-left corner of the picture I’m posting, you can see the gold film slightly separated from what appears to be an underlying glass area. I don’t think this gold film is the digitizer, but I could of course be very wrong. I’ve watched several YouTube videos and none shows this gold film. Can anyone please throw some light on what it could be?
Bu yanıt yardımcı oldu mu?
Puan 4
6 Yorum:
Hi iyoungstai. I thought the pictures were attached and when I tried to edit to re-attach them, my post was deleted. Looks like the system thought it was spam. I’ll try re-attaching here again now - hopefully this doesn’t get deleted again.
[image|2162390]
[image|2162391]
tarafından
@ryan_nyc yea, so that is part of the digitizer. and on that digitizer on the glass side would have the black tint which is the polarizer film. basically the screen is scrap now and cannot be fixed.
tarafından
Oh wow... and to think I was extremely careful with this. I don't see how it's possible to remove the glass only then if this is the digitizer, being as it's so thin and attached to the glass. So sad. :(
tarafından
@ryan_nyc posted an image for your reference
tarafından
I just saw a video on YouTube where a guy removed the back cover, battery and Sim card holder. Placed the phone in a freezer for maybe 30 minutes. When he removed it, the glue was hard and the glass pryed right off.
tarafından
1 tane daha yorum göster
Yorum Ekle
Without pics I can’t be certain. But here are a few things I can let you know.
Glass is suppose to be clear. If you removed the Glass only it should also be clear with black borders. Your LCD that is still on the frame should be black (see image), if it does not look like that, you probably removed the Polarizer film along with the glass and it is still on the glass. In that case your LCD is damaged. Try testing to see. I also added an image of the LCD’s back side if it were removed from the frame.
Puan 2
1 Yorum:
All of the questons have the same answer. ..... The glass is clear.
If it isn't you removed the polarizer. The polarizer is bonded to the
glass., but surprisingly not the LCD, except for a sliver round the edges.
That's why everyone took it off so easily. The misleading answer about the gold bit being adhesive. Adhesive is also clear.
The gold sheet is actually the LCD.
The polarizer has thin glass attatched. The LCD doesn't.
The polarizer is attatched to the LCD and they work together.
The ribbons are shared.
If you took off the polarizer , you destroyed the LCD.
And no, there is no chance of buying them seperately.
tarafından
Yorum Ekle
If you look at the picture above, the gold on the back of the display is adhesive. I’m not sure why it’s gold however. As far as I know, you can rip it and the LCD and digitizer will still work. In our store, whenever we do screen repairs on any phone, we always get the glass and LCD as one component. I’ve never done a glass only repair but from what my understanding is, it’s a pain in the rear end and it’s not easy. You will spend more for a full display unit but you will thank yourself in the long run as it’s much easier to work with.
Puan 2
Yorum Ekle
@ryan_nyc below is how it should look if the glass was removed correctly. Note that there should be glue residue but this one has been cleaned and is actually off the frame also.
Puan 1
8 Yorum:
Thanks @iyoungstai. Yeah, mine looks nothing like that - at least not without the gold film being stripped off. Guess I never had a chance. :(
tarafından
This has just happened to me, I heated the glue under the screen and it came off much easier than expected. However, I now realise that the polarizer film came off with the glass too. So now I just have a phone unit with the gold on it. Is this salvageable (ie buy additional parts) or does it mean it all has to go in the bin now?
tarafından
I have the same problem on a s10 plus is it just to throw it away?
tarafından
I have s10+ also and was wondering if you ever found the answer to gold film stuck to glass?
tarafından
tarafından
3 tane daha yorum göster
Yorum Ekle
I was trying to replace the glass on a Galaxy S9+ and the polarizer came off with the glass.I bought it as a refurbished phone and I'm guessing the glass was replaced during the refurbishment and glued to the polarizer which may explain why it came off with the glass. Wondering if any of the others posting here with this problem were also working on a phone that had the glass replaced before.
Puan 0
1 Yorum:
I seem to have a silver film still on the frame / lcd screen. But also a filming the back of the glass I removed ? The film on the back of the glass is tinted ?
tarafından
Yorum Ekle
any input ? All video show just the black ll( i assume lcd screen ) left after removing the glass. What am I missing here. does the silver film stay on the frame after glass comes off or is it suppose to all come off. As I have 2 films one on glass and one on the frame. I am lost at this point . 🤣
Puan 0
Yorum Ekle
I actually just removed an old Samsung galaxy S-10 screen and I was very careful. I got everything removed and I have a gold/silver underneath the original screen also. I held the new screen up to it has no black tint to it. The phone isn't important to me nut I was just trying to make it work for someone who could use it.
Puan 0
Yorum Ekle
Yanıtını ekle
amesiti sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 43
Her zaman: 5,962
