Ana içeriğe geç
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Soru Tümünü görüntüle
Connect to iTunes if motherboard damaged by screws? BACKLIGHT ISSUE
Hi:
I admit I may have damaged an iPhone 6 motherboard by mistakenly placing a slightly longer screw there at the display cable shield (after replacing the display). There is no display function at all. But I know the phone is still alive as pressing the power & home buttons (saved original home button) will cause the phone to vibrate. Even with the possible damage should the phone be recognized by iTunes when connected to my computer? I just want the owner to be able to download their data.
Thanks!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
There is many issues that you have to insert password and trust to connect.Yes PC detect the phone but you can`t enter password,So i think without solving the long screw you can`t connect to PC anymore.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
OK… Thanks for your response.
Would using a 1.65mm screw in place of a 1.2mm result in the damage? From just and extra 0.4mm? Is it possible to remove the screw post to repair a trace in the board? I have made SMD circuit boards and have a hot air rework station to use. Any other suggestions to save the phone?
tarafından
Yorum Ekle
Hi:
I now realize the LCD/Display is working, it is the back-light that is not. No motherboards damage due to the screws! Now on to how to fix the back-light problem.
THanks!
Puan 0
Yorum Ekle
Yanıtını ekle
Tom sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 4
Her zaman: 106
