Ana içeriğe geç
The Mazda Millenia is an executive car produced by Mazda, a Japanese automaker, between 1993 and 2002.
How to change ignition
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
4 Yorum:
James Clark ignition what? You need to tell us what the issues are and what you are trying to accomplish. Try to use more than 4 words ....;->
tarafından
@James Clark Do you want to change the ignition switch assembly, if yes, do you also have a security system (anti-theft)? Typically you will need a hammer and very sharp chisel as part of the process but lets see exactly what it is that you need to do first please.
tarafından
Ignition switch?
With lock cylinder, or without?
or,
Ignition module?
Ignition lockout/immobilizer?
Ignition relay?
More information required.
What are the symptoms, or how was the ignition diagnosed as the issue?
Help ‘us’ help you!
tarafından
My bad, just saw someone covered those details, thank Turkey and Duane, they're right on point.
Regards.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Here are the instructions for replacing the switch:
Disconnect negative battery cable. Remove steering column upper and lower covers. Remove screw(s) retaining ignition switch to steering column. Disconnect ignition switch harness connector. Remove ignition switch. To install, reverse removal procedure.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
hope this helps
tarafından
Yorum Ekle
Yanıtını ekle
James Clark sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 830
