Ana içeriğe geç
Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
433 Soru Tümünü görüntüle
iMac has a black screen, could it be the Inverter?
Been looking through similar posts but my problem appears to be different to those i have read.
I have no way of connecting the imac to another display at the moment, but everything appears to be functioning correctly except the dead lcd. I managed to get a cd to play in itunes by putting in a cd so im guessing its not a problem with the logic board?
First time this happened was about three days ago, the screen went to black but with a hint of brightness.So after shutdown and leaving for a few minutes the screen is back to normal.
Yesterday the same thing happened, and after rebooting i would get the usual grey apple start up screen and now to a completely black screen at the point you would login. After many attempts, i now have just a black screen at start up with no apple after the chime. I can still play a CD.
Ive managed to find the same inverter i need online, but would like some opinions on this before i go ahead and buy. Hopefully there is not a problem with the LCD. Thanks for any advice! Great site BTW!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
5 Yorum
Hold a flashlight to the screen at an angle and see if you can discern the desktop.
tarafından
No nothing, by the way i should have said. Only L.E.D's 1 & 2 are on.
tarafından
Also what cable would i need to plug into another imac, or hd tv?
tarafından
In a repair center we've seen a greater number of 0KM iMac having video problems...
tarafından
Pretty sure its the graphics card now as im not getting any output on an external display. Is there a guide on here for removing the gfx card? I could only find it for the 2009 20" EMC 2133 model.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
If LEDs 1 and 2 are
on and you heard the
startup sound, but
LED 3 is off, video
card may either be
installed incorrectly
or need replacement.
Bu yanıt yardımcı oldu mu?
Puan 5
9 Yorum:
How can i identify the VIdeo Card? This modes has the 8800 GS
tarafından
Please give the last three figures of your serial number (found on the bottom of the stand"
tarafından
last three digits........ 0KM
tarafından
Apple iMac "Core 2 Duo" 3.06 24-Inch (Early 2008) Specs
Identifiers: Early 2008 - MB398LL/A - iMac8,1 - A1225 - 2211
tarafından
4 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
David sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 2,796
