Ana içeriğe geç
Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
20 Soru Tümünü görüntüle
Fan starts for one second then it turns off
Hello
my mac mini starts by its own when I plug it into power and then it keeps starting up fan spins for a second and the led light turn on for a second at the same time . I check the power supply output voltage and it is 14.8 V on four pins and 0V on four pins and one goes from 0.9 to 2.6V when the fan spinnes. I alredy checked the power button and tried to start it with only power supply pluged but it is the same I checked the logic board and it looks in good condition. Hope to find the answer?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
Given that you asked this question today, I have to ask: any OS installs lately?? Catalina maybe? On an external drive perhaps?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Your power supply is bad! Here’s the needed part Mac mini A1347 (Mid 2011-Late 2014) Power Supply and here’s the guide to replace it Mac mini Late 2012 Power Supply Replacement
Replace a broken or damaged power supply in your desktop computer. This power supply is compatible with a Mid 2011 to Late 2014 Model A1347 Mac mini small desktop computer. Görseli
Ürün
$29.99
Bu yanıt yardımcı oldu mu?
Puan 0
5 Yorum:
But that is only 2.8V more than 12V older mac mini models accept from12-17V
tarafından
@luka11lavric - Why does that matter?
Are you seeing any output on the display screen alters its color or you see the Apple logo? The fact the fan spins up for a short time doesn't prove the power supply is good as the load of the logic board can cause the power supply to fail. Which is what I suspect here.
As I stated I would replace the power supply, if that didn't fix it then your logic board is bad.
tarafından
Ok on the display I do not see anything
Can you please explain what is the load of the logic board? and If I can somehow test if that is the problem?
tarafından
And also the power supply put out all the time 14.8V even when the fan stops spinning. I do not know if that means anything
tarafından
Think of it this way... I have a go-cart if I raise the wheels I can run the engine full out, but if I try to run it up a steep hill with a large load it won't move very fast and the engine might knockout. So the power of the engine with no load is just great! But the load you are placing it under won't let the cart go at the same speed.
This is the same with power! You can have the right voltage with the board not wired in and as soon as you do the board is not able to work.
The choices are clear it's either the power supply or its the logic board. I'm betting on the Power Supply as they often go, and is the cheaper possibility.
tarafından
Yorum Ekle
Yanıtını ekle
luka11lavric sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 17
Son 30 gün: 27
Her zaman: 2,103
