Can anyone tell me how do I use the flex extension?
Can anyone tell me how do I use the flex extension in Ifixit pro tech kit?? It’s not magnetic.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi @kmredul
Push the bit into the hollow end until it is stuck in place. It will need to be pushed a little harder versus putting the bit directly into the driver. If the bit is not magnetic, you can attach a small magnet to the bit or rub the bit itself against a larger magnet.
Bu yanıt yardımcı oldu mu?
Yeah, I figured it out. BTW thanks for your help.
The 150mm Flex Extension in the 64 Bit Driver Kit (Mako/Pro Tech Toolkit) does not have a magnet. The slot uses friction to secure the bit, unlike the iFixit Drive Handle which uses a magnet. If you insert a bit and then push it in with additional force it will click into place. To remove the bit, simply pull the bit up and out from the socket and the friction grip inside will release it.
If you're not able to get the extension to hold the bit, please Contact Us with your order number.
Son 24 Saat: 10
Son 7 gün: 61
Son 30 gün: 172
Her zaman: 4,890
