Ana içeriğe geç
20 Eylül'de piyasaya sürülen Apple'ın 2019 yılı ana akım iPhone modeli; 6,1 inç LCD dokunmatik ekran, çift kamera ve altı farklı renk seçeneğiyle geliyor. iPhone XR'ın devamı niteliğindedir.
Screen replacement compatible with XR?
My iPhone 11 screen has cracked and I cant find an 11 lcd screen replacement to buy anywhere online to repair myself. After some looking for picture of both the XR and the 11 under the display and the screens itself they look very very similar. Could I possibly buy an XR display and use it on the 11 with it fitting properly?
Bu iyi bir soru mu?
Puan 4
1 Yorum
XR is not Compatible with 11
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
The display modules look the same, but you can’t install the screen from iPhone XR to iPhone 11 because they have technical incompatibilities.
Bu yanıt yardımcı oldu mu?
Puan 5
Yorum Ekle
No. They may look the same but they both have something that prevents you from using a xr screen on a 11
Puan 1
9 Yorum:
https://youtu.be/AIgTrL9xbV0
you cannot interchange 11 & XR or vice versa! See video.
connectors are different.
=== Update (01/02/2023) ===
After reaserching and actually trying a swap from 11 to XR I found they do not work. So no compatability.
tarafından
I connected an XR screen to an iphone 11 and the display works but touch does not.
tarafından
I have also plugged an iPhone XR screen onto an 11 only to find out that the touch did not work as someone else said. You can trim the excess width from the display plug and then plug in vice versa from the way the XR screen is suppose to plug in and then you realize the connectors are the same but again, as someone else here answered, technically they are different somehow bc you end up with no touch. I’ve never had any issues switching btwn series 7/7plus and 8/8plus screens tho.
tarafından
I posted this long ago and recently I have found that they are different FPC connectors on the flex and and the boards, ie sizes do not match. Thanks for your reply. I do know about the 7/7+ and the 8/8+ screens and did you know the batteries also are compatible ie 6s/6s+ with 7/7+, and the 8/8+ I think the X can work for testing purposes as well, not sure cuase I have not tested that yet.
tarafından
If you flip the connection around they will plug in but touch won't work. I did this about 2 weeks ago.
tarafından
4 tane daha yorum göster
Yorum Ekle
So, the XR screen will power on on an 11. But touch may not always be consistent and could have problems. And 11 screen on an XR may power on at best, but no touch. An 11 screen may not even power on at all on an XR. So you might be able to use an iPhone XR screen on an 11, but just prepare for inconsistent touch and potential touch issues, as well as losing True Tone and Face ID.
Puan 0
Yorum Ekle
Yanıtını ekle
Splityou4 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 43
Son 30 gün: 184
Her zaman: 38,888
