Ana içeriğe geç
Repair guides and support for motorcycles manufactured by Honda.
speedometer and tach lights not working.
i have a 96 honda gl1500 se. the dash lights work but the speedometer and tach lights do not. any thoughts?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 4
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
  • Speedometers are unique in that some of them use physical cables instead of sensors, so a speedometer not working can also indicate a broken cable or stripped gear.
  • If one or more warning lights fail to illuminate when you first turn the key on, it usually indicates a blown bulb.
  • If none of the lights come on at all, check the fuses and wiring to the instrument cluster first.
  • If a warning light comes on and stays on when the engine is running, that usually indicates a problem with that specific system.
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
I am sorry I wasn't clear on the request. What I meant was everything is working properly except the lights on the speedometer and tach. Makes it very difficult to drive at night.
tarafından
tarafından
Yorum Ekle
Speedometer light Horan not working
Puan 1
Yorum Ekle
I have a splandarbike but many problam this bike Bhai is smoking and the noise is very directly and not speed
Puan 0
Yorum Ekle
Yanıtını ekle
ken_choat sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 37
Her zaman: 3,260
