Ana içeriğe geç
4 Kasım 2017'de satışa sunulmuştur. Model A1865, A1901. GSM ya da CDMA olarak 64 ya da 256 GB kapasitelerinde, Gümüş ya da Uzay Grisi renklerinde satılır. ("iPhone 10" olarak da telaffuz edilir.)
1199 Soru Tümünü görüntüle
iPhone X restarts every 5 minutes after backreplacement
Hello,
I switched the backglass and the frame but since then my iPhone keeps restarting every 5 minutes. The new backframe arrived with parts like charging port, taptic engine. I’ve kept them inside. The crash report of analytics is:
{"bug_type":"288","timestamp":"2019-10-13 18:42:47.85 +0200","os_version":"iPhone OS 13.1.2 (17A861)","incident_id":"8C446476-CA19-47A0-8F74-5803B0A9A4A8"} { "build" : "iPhone OS 13.1.2 (17A861)", "product" : "iPhone10,6", "kernel" : "Darwin Kernel Version 19.0.0: Tue Sep 3 21:52:10 PDT 2019; root:xnu-6153.2.3~2\/RELEASE_ARM64_T8015", "tuning" : { }, "incident" : "8C446476-CA19-47A0-8F74-5803B0A9A4A8", "crashReporterKey" : "413cb2f10b0936293a261e8ec514288966bd25a5", "date" : "2019-10-13 18:42:47.85 +0200", "reason" : "(1 monitored services unresponsive): checkin with service: com.apple.thermalmonitord returned not alive with context:\nis_alive_func returned unhealthy : current 1ffc73fffffffff, mask 67fffffffff, expected 67fffffffff\nno successful checkins since load (130 seconds ago)", "frontmostPids" : [ 58
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
1 Yorum
I definitely have the same problem, I reset the settings, I did a hard reset, but the problem continues
problem is iphone se
edit: model
tarafından
Yorum Ekle
7 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Ive seen this happen a few times. When you put the motherboard back in, did you happen to tighten the screws too tight? Sometimes just that, will cause it to fritz and send it into boot loop which at that point, would have to be fully replaced because a part of the mobo is destroyed. Something just that small will cause it..
Ive seen this happen on almost every single model up to the XS max. It is possible
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
I Had the same problem with an iPhone X after replacing the charging port, Solved this simply using an original salvaged charging port, 100% fixed. Some aftermarket charging flex cable aren’t working on iOS 13.x, They’re messing with something related to the thermal system, and forcing a kernel panic. (PS=The phone will keep restarting without any charging port,too).
Puan 1
1 Yorum:
Hi, I have the same issue on an iPhone XS Max, it restarts it self only if I'm using it. The logs report the same error. It could be the charging port? Where I can find an original one?
tarafından
Yorum Ekle
You might have damaged the charging port flex. You can also check the USB IC under the microscope.
A rare case of iPhone X Keeps Restarting - Motherboard Repair
Puan 1
Yorum Ekle
Check the charging port to see if there is any dust.
Or try restart it forcefully.
Puan 0
Yorum Ekle
@vicmohamed : I agree with your solution to this problem. I too just replaced the charging port to a water damaged iPhone XS with an after market replacement- I had no idea why the XS kept restarting after exactly 3 minutes. I spent a good amount of time researching the problem, and narrowed it down to the phone’s analytic reports showing the thermal system not being communicated with and causing the Kernel Panic. I saw these postings, re-opened the XS, and replaced the charging port with the old OEM (cleaned with 99%ISO) charging port cable. Problem immediately solved. I hope everyone has a similar experience and gets their phone working! Good luck
Puan 0
Yorum Ekle
I did not connect power board, vibration flexy and keys flexy in the charging socket. nevertheless, the device is turning off with the same error, CPU usage is 100%.
Puan 0
Yorum Ekle
Damage to the wireless charging pad on the back of the phone.
Puan 0
Yorum Ekle
Yanıtını ekle
Icon sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 9
Her zaman: 4,901
