Ana içeriğe geç
Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
340 Soru Tümünü görüntüle
difference between lm270wg1(sd)(f1) and lm270wg1(sd)(f2) lcd
or can I use another type, my screen is black but it is not the graphics module. (shining with a strong lamp I see the icons)
Thanks for any solution
Update (10/15/2019)
So, i must replace the whole motherboard (
). Is there and layout of the connector (power)?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
Sadly, your logic board does need repairs. Replacing it would be anther option.
If you had opened the system to alter your drives and you encountered this afterwards I would also check the power cable.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Then your backlight power logic is your problem not the display its self.
The logic around the power connector on the logic board.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
hasselaer sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 158
