Ana içeriğe geç
Model A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 or 3.8 GHz Core i5 or 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K display. Refer to the older iMac Intel 27" Retina 5K Display (Late 2014 & 2015) guides as the system is very similar.
293 Soru Tümünü görüntüle
iMac 2017 (18.3) - Blade model : Mounting brackets needed?
I was asked the possibility to add a SSD drive to a blade only model (18.3 3.5 ghz Retina). Do I need the right and left mounting bracket to install the adaptive 3.5 to 2.5 socket ? Since it’s a blade only model, did Apple put them anyway inside ?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
It’s a really good question. I have a fusion, so I don’t know for sure.
You should get some on AMZ, in case, then once you' have the iMac open you’ll be able to decide to use them or return them:
https://www.amazon.com/Apple-A1311-Brack...
Also, I would recommend an adapter: https://www.amazon.com/gp/product/B01ELR...
Here is my SSD now:
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Samsung drive in an iMac ... edgy
tarafından
Yorum Ekle
Yanıtını ekle
Seb sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 51
