Ana içeriğe geç
16 Eylül 2016'da satışa sunulmuştur. Model 1660, 1778 GSM ya da CDMA olarak 32, 128 ya da 256 GB kapasitelerinde ve Altın Gülü, altın, gümüş, siyah ve simsiyah renklerinde satılır.
2264 Soru Tümünü görüntüle
Another Touch ID not working question
I bought an iPhone 7 with a screen that had a single crack in it. Tested it and everything worked fine including touch id. Had an extra screen laying around that may have been water damaged and thought I would test it just to see if it worked, which it didn’t.
When I connected the old cracked one back touch id wouldn’t work anymore.
First it reacted like I was double tapping. Inspected every cable and pin, but can’t find any breaks. I also did an DFU reinstall, but touch id still won’t work.
When I try to add a fingerprint it doesn’t register anything.
The home button works fine besides touch id.
What could the fault be?, could the screen I test fitted have caused damage?.
When I removed the old screen I didn’t touch home button flex cable, but could damage to the other three flex cables that connects to the logic board result in symptoms like the ones I have?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Got the new screen and the culprit was the flex cable on the screen itself.
Changed the screen and now Touch id is working .
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
if the homebutton is super sensitive then its usually the flex on the actual homebutton that is damaged.(usually from opening the phone wrong).
Also check the flex on the screen, its the smaller connector that is responsible for the home button and is easily ripped where it bends through 180deg.
Puan 0
1 Yorum:
I can't see any tears on the cable, but it sort of looks a little bit "wrinkled". The home button flex cable looks 100%.
I also had trouble with the screen not responding after taking it apart again, but that started working after going over the connections once more. I've ordered a new screen so hopefully the culprit is one of the flex cables that's attached to it :).
tarafından
Yorum Ekle
Yanıtını ekle
MacBain sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 4
Her zaman: 55
