Ana içeriğe geç
Model A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 or 3.8 GHz Core i5 or 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K display. Refer to the older iMac Intel 27" Retina 5K Display (Late 2014 & 2015) guides as the system is very similar.
293 Soru Tümünü görüntüle
Looking for Logicboard Schematics to locate F4400 and F8100
Looking for schematics of the logic board of a 2017 27” iMac. Symptoms are black screen at start up and fan at full speed. 4 (rather 3.5) out of 5 diagnostic LEDs are lid but there is 0 signal from the LCD. I am trying to see if i have failed fuses F4400 or F8100 as of the Technician Service Manual. But i cant really exactly make out which components are the right ones. Schematics would help me a lot here.
Thanks!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
11 Yorum:
Can you give us some background on what happened. The more details the better.
tarafından
more info please
tarafından
Bought the Mac as parts. Looks like the po removed the screen and broke the lvds connector and cable. I suspect when reassembling the connector causes a short. The Mac runs fine with external screen. 4 out of 5 diagnose leds are lid. I tried to measure the fuse today but I am unsure which one is the fuse. Trying to figure out where exactly F4400 and F8100 are and what specifications they have.
tarafından
so u dont know where they r?
in that case give me a few ok?
tarafından
Yeah I know f4400 is located close to the connector and f8100 is on the other side of the logic board, but I just don’t know exactly where they are and their specifications
tarafından
6 tane daha yorum göster
Yorum Ekle
4 Cevap
Filtre ölçütü:
found the f4400 fuse that is the display fuse on third page that you posted it is number 5 look there and the f8100 fuse is number 24 on the sheets you put on hope that helps
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Yes I know that, that’s how i figured out that there are fuses in the first place, but from the pictures it is not clear what component exactly the fuse is and what the specifications are. In the boxed area are 3-4 different components...
tarafından
Yorum Ekle
It looks like you gave us a good clue! It does look like the 2017 follows the Late 2014 & 2015 models.
Here’s the clue you gave
And here’s the 2014 logic board with the Fuse ID’ed
As to its value I just don’t know!
You still have a SMC issue which is why your fan is running hard.
Puan 0
1 Yorum:
Getting closer, the only problem is that the 2017 looks slightly different, I can identify a fuse there, but it is marked with an N and not with a P in the 2014 model. Edith: checked your picture and the fuse says N as well. So I just need to figure out the specs of this fuse
The smc issue is due to a missing temp sensor on the ssd, going to address that with the appropriate cable including the stick on sensor.
tarafından
Yorum Ekle
Do you have the page with items 6 through 13 listed? Thank you very much
Puan 0
2 Yorum:
#6 - Diagnostic LEDs 1–5
# AC input voltage (trickle power present)
# Power supply DC output voltage
# Memory is functioning
# GPU is functioning
# Display panel is connected
#7 - Display power (backlight control)
* No LED backlight on internal display
* Open backlight fuse F8100 on logic board
#8 - Right speaker
* No sound from right speaker
* Distorted sound from right speaker
#9 - Audio input/output
* No external analog audio input
* No external analog audio output
* No headset controls or mic input
#10 - Microphone
No input or distorted internal microphone input (with Internal Microphone selected in Sound Input Preferences)
#11 - RTC reset pads (TP1902 and TP1093)
Short across to reset Real Time Clock (RTC)
#12 - Power on signal and power supply temperature sensor
* No power
* Intermittent shutdown (if cable is pinched or damaged)
* Fan runs at full speed
#13 - Backup battery test points (TP1900 andTP1901)
Used to measure 3V DC backup coin battery voltage
tarafından
Thank you so much. You are very kind.
tarafından
Yorum Ekle
Hi, Same problem here, exept the lcd is working but NO backlight ! I try to find the location for the backlight fuse (F8100). Thanks :P
Puan 0
Yorum Ekle
Yanıtını ekle
pvfahrer sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 15
Her zaman: 920
