How to remove the digital crown on an Apple Watch
I want to remove the nut so I can swap the crown and housing. Is there a way to get a new nut that holds the crown and sensor or can someone tell me how to remove the nut.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Boy! I haven’t seen any need to go that far.
First you’ll need to take most of the watch apart to get the sensor assembly off to make room for the screw to exit (not a nut). It will require a special wrench to hold it as you turn the digital crown. As you can see it has two flat surfaces for the wrench to grab.
What are you doing that you need to go that far??
Bu yanıt yardımcı oldu mu?
Ok I bought a special housing unit but it does not give me that piece.
Do you know what special tool is used for that ???
I would make it, basically using a thin piece of tool steel carefully grinding it down into a custom wrench. One of these might work too Moody Tools 57-0122 16-Piece English / Metric Mini Open End Wrench Set
Ok thanks alot
Time stamp 14:24
Rami Abdi where in the video does he show how to loose the Digital Crown?
did you find out if you could get a new nut ? i need one too.
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 50
Her zaman: 11,307
