Ana içeriğe geç
Repair information for the Crusher Wireless headphones. Model number: S6CRW-K591. First available on Amazon in August of 2016.
The turning mechanism between the earpad and the headband broke.
After almost one and half year my headphones just broke when I wanted to put them on. I was very surprised that this happened and I'm also very sad because I can't even wear them anymore. The sound and everything is just fine.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 6
4 Yorum
Did you find a solution? I'm having the same problem and I'm looking for the replacement part to print it with the 3D print... But I can't find it...
tarafından
I duct taped it together until I got back home. (I was on an international internship). Then my dad gave me money to buy a new one.
tarafından
@Floortje B hahaha Ok thanks
tarafından
ok so I need the part that's still connected to the earmuff... the plastic piece with the 2 screws on the bottom of the first picture
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Floortje B  the only way you can fix that is by either having someone 3D print you a new part for it or you’ll find another pair that is broken other than the hinge part. Looks like the 2 screws are the only thing that hold those to your headphone. Removing those most likely enables you to replace the broken part.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
I figured out a temporary fix. I am posting this for others arriving here from search engines and the like. I assume OP's problem has long been solved. My fix is based on somebody else's fix.
I have 3D printed parts on the way, but my 'design' may actually press down on my ears better than the original. 🤔
What you'll need:
-Tie rip 2 mm
-Tie rip 4 mm
-Drill + 1,5 mm drillbit for metal
-Strong thin elastic.
-Pliers (for making sure the tierips are real tight.)
Alt for picture: https://imgur.com/a/TcRGRT2
Puan 1
2 Yorum:
Great quick fix! If you find the time, create a step by step guide for this!
tarafından
@amber No time, this is what I got. It's pretty detailed already.
tarafından
Yorum Ekle
My device is broken exactly at the same point today. I fix it by drill a hole from one site to the other (1,2mm thick) and insert a steel pin (as it is used in watches). I used black tape to prevent fall out of the pin.
If anybody is 3D-printing original part, I would like to order one!
Puan 0
Yorum Ekle
Yanıtını ekle
Floortje B sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 24
Her zaman: 2,022
