Ana içeriğe geç
4 Kasım 2017'de satışa sunulmuştur. Model A1865, A1901. GSM ya da CDMA olarak 64 ya da 256 GB kapasitelerinde, Gümüş ya da Uzay Grisi renklerinde satılır. ("iPhone 10" olarak da telaffuz edilir.)
Poor GPS quality after screen replacement
I have recently replace the display of an iPhone X after it receive an hammer, now the GPS present issue, is really inaccurate and doesn’t work well with navigator apps but a few times it works fine.
I would like to know if it cause by the screen replacement or by something else and possible solution
Thk
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Was this little gold piece placed back in step 22 of this guide?
iPhone X Screen Replacement
Bu yanıt yardımcı oldu mu?
Puan 2
3 Yorum:
Yes, I'm gonna check if I place it in the correct position place as show in the pictures, in case is not in the correct place can that be the issue ?
tarafından
Not 100% sure but those grounding pins do have an affect on the antenna strength as the housing is essentially an antenna.
tarafından
Well I check and the little gold piece was in the right place, and still having issue i try with GPS status to check the accuracy and while my iPhone XS can have a 5mt accuracy the iphone X doesn't go lower then 32mt.
Also i try reset location and network ecc. like in some guides
tarafından
Yorum Ekle
i have the same issue…..
thought about replacing the antenna but…. is the WiFi antenna is the one i should replace? (its at the bottom of the phone and has nothing to do with the screen replacement procedure…)
i cant find any GPS antenna….
Puan 0
1 Yorum:
I have the same problem after doing a screen replacement - GPS worked fine before screen cracked from being dropped. I did the screen replace and now no GPS. I don't think replacing the wifi antenna will help GPS reception. I called an ifix store and they said GPS is in the motherboard. Going to try factory reset next.
tarafından
Yorum Ekle
Yanıtını ekle
Daniele Zamboni sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 18
Her zaman: 5,965
