No spark on 2&3 cylinder
I have a good 12v power and ground at the coil but no pulse.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
@smitty9448 If the coil is new, teh wires new and you still have no spark I would suggest you check the wire on connector to your coil to see if you get a signal. You will need a tester that can measure hertz. It is the fuel injection computer that triggers the signal to your coil.
Bu yanıt yardımcı oldu mu?
The hertz inspection is good but I believe on this engine that the Cam Position Sensor signal will be fluctuating from a strong signal to a weak signal as the camshaft bore is probably worn out due to lack of proper maintenance and oil changes. This will show up on a signal trace via an oscilloscope.
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 1,095
Have you tried changing out the spark plugs
Noah tarafından
@smitty9448 1.6 or 2.0 engine?
oldturkey03 tarafından
Yes i have even changed the coil.
John Smith tarafından
Yes it is a 2.0
Just to verify, cylinder 1 and 4 have spark but not 2 and 3? You replaced the coil for 2&3? Do you have a meter that can test Hertz? you replaced the plug wires as well?
1 tane daha yorum göster
