Ana içeriğe geç
The fourth-generation Surface Pro tablet, released October 26th, 2015.
Surface pro 4 screen replacement
Hello, i’m new here.
I would like to ask you if you could tell me which screen is mounted. I read that there are two versions and that the sp4 tablet is born with the Samsung screen. Subsequently, due to flickering problems it appears that the screens have been replaced by LG screens.
below I post a picture.
I would also like to ask you if the model in ifixit is compatible with my device and that I avoid the flickering effect
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Hi pisanivito,
I believe your broken display is an LG sourced display. I have attached an image of a Samsung display. The differences are subtle and they are interchangeable, provided you use the correct connectors. If you choose to use the IFIXIT display, it will be compatible with your Surface Pro 4, but you will need to order the correct display connector PN: X937072-001 . The N-Trig Digitizer should just be a hot-swap and although your connector for that looks different from mine, it should work with a Samsung display just fine.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Hi Logan, pianivito,
I am doing the same upgrade myself. M1010537-003 is the correct part number for the LVDS display cable to upgrade a Surface Pro 4 to a newer LG display. Cable X937072-001 is for the Samsung unit in your screenshot
Cheers, Neil!
Puan 0
Yorum Ekle
Yanıtını ekle
pisanivito sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 16
Son 30 gün: 41
Her zaman: 860
