Ana içeriğe geç
LG G Pad 8.3 4G, Verizon tarafından Ekim 2013'te piyasaya sürülen 8,3 inçlik (21 cm) bir dokunmatik ekranlı tablettir. Tablet, arka kapağın alt kısmında siyah mürekkeple yazılı olan "ZNFVK810" FCC kimliğinden ayırt edilebilir.
Opened device looks different!
Hi,
Pried the screen off and what I see is totally different from the picture in step 2.
It appears that I am looking at the backside of the battery.
The LCD is to the right, the left side shows the back side of the battery and the frame covering the battery.
Resim
Resim
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
2 Yorum
I know the black frame should be at the back of the LCD but that was the only way I could pry this thing open.
Model is LG-VK810
tarafından
I have added a pic of the back panel. It's different from the video you sent me.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@esebm totally possible but you need to know which guide you followed. Only you know where you started from. Post some pictures that show what you are looking at with your QUESTION. That way we can probably help you out further. Also, let us know what you are trying to fix. Mevcut bir soruya görsel ekleme
Update (10/31/2019)
Looks like the black frame on the left should be on the back of your LCD on the right. What is the actual model number for your tablet?
Resim
Bu yanıt yardımcı oldu mu?
Puan 1
11 Yorum:
I followed that guide: LG G Pad 8.3 4G Battery Replacement.
When I pry the display off I don't see the pic in step 2, just the plastic frame.
There must be a way to pry off the back panel in order to get to the battery.
tarafından
It sound sto me that you got somewhere under the LCD and separated that (the LCD from the frame) one. the guide you described is the right one so that is not it. Again, pictures of what you are looking at would help us to help you.
tarafından
Yes, I did separate the LCD from the frame, that's how I interpreted step 1 in the guide. The back panel can not be removed by moving the spudger around the perimeter. The back panel on my unit is about 1/2" indented top and bottom and does not go around the perimeter.
tarafından
Any help here?
tarafından
Sure looks like you used the wrong guide. Looks like you pulled the LCD of the motherboard. Take a look at this video https://www.youtube.com/watch?v=27azAfFh... around 1:19 you see your LCD and sure looks like what you are looking at on your picture. If your LCD is still connected etc., you can always try and repair it by following the video
tarafından
6 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Ed Miller sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 17
Her zaman: 571
