Ana içeriğe geç
Mart 2017'de piyasaya sürüldü, SM-J727 model numarasıyla tanımlanabilir.
J7 Crown Black Screen
I have a J7 Crown S767VL that has no screen display it stays black phone is still powered on and when I try to hard reset it doesn't fix the issue I have tried to power off by holding power + volume down button for 20+ seconds and after about 15 seconds of holding buttons it vibrates every 1-1.5 seconds and does not power off. I have been attempting to factory reset with black screen with no luck and have exhausted my options available online. Please give me suggestion(s) on what I can do it is a straight talk phone.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 4
Yorum Ekle
1 Cevap
Filtre ölçütü:
It sounds like an LCD fault. Has the phone been dropped in water or dropped on a hard surface?
Bu yanıt yardımcı oldu mu?
Puan 0
12 Yorum:
I do not believe it has gotten wet or dropped, it is in pretty pristine condition as far as I can tell I was thinking it was a corrupted firmware issue
tarafından
You will need a new LCD if you haven taken phones apart then you can replace the screen yourself or take it to a repair shop. It will be a whole lot cheaper replacing it yourself if you do that go here https://www.amazon.com/Replacement-Digit...
tarafından
Is there a way to try to perform a factory reset without the ability to boot in recovery mode and being unable to do it through settings?
tarafından
Hope this helps
tarafından
Yes if you have a computer
tarafından
7 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Corbin Dallas sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 21
Her zaman: 1,936
