Error code B200 on PIXMA MX870
What is B200 error? All I find in Canon support is “unplug and contact service”. No help or explanation of the problem whatsoever.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Canon Error B200 generally relates to a printhead issue and an error message of support code B200 will flash on the control panel. Check this video as well as this one for possible solution. There are plenty more out there that will address the issue Last one is a bit funky but it gives a possible solution
Bu yanıt yardımcı oldu mu?
Hi @danooch
Is it still under warranty? if so, send in for service,
else you can try on the suggestion provided at the below link
https://appuals.com/step-step-guide-reso...
Let us know what steps you had tried and observe the behavior.
The last step which could be a print head failure.
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 2,230
1 Yorum
Check out this article to resolve the issue. Most importantly, the problem can be solved by reinstalling the printer driver. Follow this article https://silicophilic.com/canon-b200-erro... if the problem could not be solved.
Thomas Kutch tarafından
