Ana içeriğe geç
Ocak 2015'te piyasaya sürülen Android tablet. Dell Venue 8 7840, 2560 x 1600 piksel çözünürlüğe sahip 8,40 inçlik bir ekrana sahiptir.
Screen Tearing and Low Battery
NOTE: Not a Dell Venue 8 7840
Hello, Recently bought a Used Dell Venue 5050 (Not Pro) it booted up fine then Last Night i started getting Screen Tearing wondering if its the battery or the O.S.
Also its running android Lolipop
And Battery was only holding 25% Charge as of Last Night
Thanks in Advance, Andrew
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
@born7 screen tearing should not be a battery issue. That is usually caused by the OS and/or memory. Try to charge your battery completely and then reset your software.
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
Then what would you recommend how do i run tests for bad memory or O.S. on Android or do i have to connect it a computer and factory reset it
Also how do you go about factory resetting this model of Dell Venue (5050) (Non Pro)
tarafından
@born7 for a reset, this should work for your tablet. https://www.hardreset.info/devices/dell/...
tarafından
now this "Battery was only holding 25% Charge" could definitely be a battery issue.
tarafından
Yorum Ekle
Yanıtını ekle
Andrew sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 16
Her zaman: 298
