Ana içeriğe geç
Dyson DC44 Animal, ev yüzeylerindeki evcil hayvan tüylerini temizleme konusunda uzmanlaşmış, Dyson'a ait kablosuz bir elektrikli süpürgedir. Model numarası: DC44 Digital Slim MK2.
brush Head not turning
The brush head on my dyson is not spinning. No blockage or tangles. Think it’s the motor. Is this repairable?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
3 Yorum:
Hi,
With the brush head removed from the vacuum cleaner, do you get sufficient suction at the end of the rod that it attaches to?
Is the battery fully charged?
Is the filter clean?
tarafından
Does anyone know where to get a replacement motor?
tarafından
For parts from my experience eBay is 9/10 the best place
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
If the suction is ok, its probably due to hair being caught under the motorised head rotator.
  1. Take out the brush
  2. With a hexagonal screw driver head, not sure what size to be honest, remove the screw from the center of the rotator.
  3. Lever out the rotator.
# Use a pair of tweezers to remove any hair, you’ll be surprised as to how much there is.
  1. You may have to add a little grease
  2. Replace rotator, tighten up screw. Ensure it can turn manually.
  3. Test by attaching to battery and pulling trigger.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
I have this problem but the brush is clear. It appears the power for the little electric motor is not being sent by the main unit down the two pins. How do I get inside to see why power isn’t getting through?
tarafından
Yorum Ekle
Yanıtını ekle
Joanne McGrath sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 17
Her zaman: 2,978
