Ana içeriğe geç
The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
623 Soru Tümünü görüntüle
Won't power on. Is it the keyboard or logic board?
Acquired a 13” MacBook Air (Early 2015)
A1466 EMC 2925 that had suspected water damage. Opened it up, cleaned the board, however didn't see any real signs of liquid, no corrosion, etc.
No response at all when power button is pushed.
Using 45w MagSafe 2 Power Adapter (A1436).
When plugged in, light is green for 2.5 seconds then changes to orange. Green light when fully charged. SSD definitely feels warm to the touch and I think I feel some slight warmth to the battery when plugged in.
Since the power button is connected to the keyboard, is there a go around to try powering on another way to determine if the keyboard has a short?
It has sat for a little over a year unplugged and on my to do list. I tried powering on with the battery disconnected and plugged into the MagSafe charger as well as by battery alone, and with battery connected while also plugged in. (Did all 3 with and without the SSD installed.)
Bu iyi bir soru mu?
Puan 0
1 Yorum
@conlledo Thanks Fernando.
I'm not seeing exactly the same points on my logic board. Can you point them out for me?
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Here are the Power on Pads for that model, just make contact between this two pads (screwdriver or some metallic conductive tool). Also you said that SSD is warm, remove it a test, modern macs power on with blank screen until they load OS, and last thing try with a external monitor may has a screen back light problems.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
Here are the pads, sorry Location of power pads
tarafından
Thank you. No response though, so guessing it's the board. :(
tarafından
Yorum Ekle
En Yararlı Yanıt
Sorry, It was for a macbook pro, Location of power pads
here are the pads.
Puan 1
Yorum Ekle
@conlledo - check out this vid The most common Macbook Air logic board failure - how to fix.
Puan 1
Yorum Ekle
Yanıtını ekle
Brownbailey sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 179
