Ana içeriğe geç
The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
623 Soru Tümünü görüntüle
Handling backlight sheets without damage
It's quite a challenge to change the backlight sheets without leaving any marks. Today I've tried (powdered) latex gloves and still some signs of fingerprints.
Any tips on avoiding this?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
I believe it should be avoided at all costs to handle backlight sheets to manage to do a clean replacement and even then it's not easy. Ideally they shouldn't be moved at all.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Non latex gloves should make the thing ;)
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
That's interesting. Can you elaborate? What's the reason behind it? I hate using artificial materials when natural and biodegradable options are available.
tarafından
Latex gloves are often powered. Nitrile gloves are better here.
Even still as soon as you wipe the surfaces of the sheets you build up a static charge which attracts dust! Years ago where I worked we had a clean box which had an ionized air flow to reduce the static charge and it had hepa filters to clean the air.
I gave up trying to replace the MacBook Air screens are its so hard to keep things clean and sometimes the sheets get damaged as well.
tarafından
Yorum Ekle
Yanıtını ekle
Sam sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 52
