Ana içeriğe geç
The Cruzer Blade is a USB 2.0 flash drive released by SanDisk.
8 Soru Tümünü görüntüle
Write protected pendrive issue
my pen drive has been write protected, format related issue.
I did everything like in registry edit, cmd command, used tools, but the problem remains same
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 14
2 Yorum
Have you attempted to use any kind of write protection removal or partitioning tools?
tarafından
usb write protected problem
tarafından
Yorum Ekle
5 Cevap
Filtre ölçütü:
En Yararlı Yanıt
First I maked the bootable USB of Ubuntu then I installed Ubuntu in dual boot successfully, but now I am formatting my SanDisk USB then it is showing me error of " write protected". I tryed most of the ways from Google but that is not working, my USB is also showing in disk manager but, I am not able to format or delete the partition, can you help me please 😢🙏
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Sadly there just isn’t any way to salvage your USB drive.
Puan 1
Yorum Ekle
Download Ease partition primary
And click own write protection clean
It will scan usb and clean its write protection problem
Puan 1
Yorum Ekle
Possible causes of read-only mount:
  • Security configurations on the Operating System; Too many to list, but they are altered using Windows Registry; Google around;
  • Corrupt Filesystem / Dirty Bit set; Use chkdsk;
  • Corrupt partition table; Use a drive partitioning utility; Pendrive will be erased but will be usable later;
  • Pen drive microcontroller reporting faults; It means it’s time to buy a new drive. I’m still looking into possible temporary fixes to make the drive last a few more days, but it looks bad.
Puan 0
1 Yorum:
tarafından
Yorum Ekle
Its seems that Cruzer Blade usb disk is awful. I have the same problem “write protected” and I have found many other posts in internet with the same problematic usb disk.
Puan 0
Yorum Ekle
Yanıtını ekle
Rohit Dharan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 24
Son 30 gün: 115
Her zaman: 4,522
