Ana içeriğe geç
Released September 22, 2017. Model A1864, A1897. Available as GSM or CDMA, 64 or 256 GB Storage Options, and the color options are gold, silver, and space gray.
678 Soru Tümünü görüntüle
wifi is grey out
i was going to replace the lightning connector flex cable in my iphone 8 plus.
I follow the steps in the guide and finished step 64, but i had to stop. The next step is to remove the lightning connector flex cable. I then follow the guide and put everything back. After i put back everything and boot up the phone, the wifi will not turn on, it does not let me toggle. I have double checked the bottom antenna and the top antenna, all seems to look fine. Please, can you suggest where i could have forgot a connector.
thanks.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Unfortunately this is not an antenna issue. If your Wi-Fi is greyed out there is a problem with your Wi-Fi IC on your logic board.
This is not an easy repair and will have to be completed by a competent microsolderer that also has access to an IPhone 8 NAND programmer in case the Wi-Fi chip cannot be reballed and has to be replaced.
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
Yanıtını ekle
cli168 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 524
