Ana içeriğe geç
Genel olarak, dahili bir ekran içermeyen ve sabit olması amaçlanan bilgisayarlar.
2134 Soru Tümünü görüntüle
First PC setup. No monitor signal at startup. Force shutdown fixes it.
PSU: GIGABYTE G750H
Mobo: ASUS Prime X570-P
CPU: AMD Ryzen 9 3900X
GPU: GIGABYTE GeForce RTX 2070 8GB
RAM: 32Gb(16+16) DDR4 G.SKILL RipJawsV 2133MHz(OC at 3200)
M.2 SSD: Samsung 970 EVO Plus 250GB
HDD: Western Digital Blue 3.5" 1TB (7200rpm)
OS: Windows 10 Pro
Greetings,
Recently(1 month ago), I built the PC mentioned above.
Lately, almost every time I press the power button to boot the pc, the fans start, the lights on the Motherboard light up, but the monitor has no signal. No beeps sound at startup. If I long press the power button to shut it down and then press it again to start the PC, it boots normaly.
I’ve tried to unplug and re-plug the components(RAM, GPU,PSU) the problem still persists.
I’ve disabled the fast start up of the windows, nothing.
I’ve reset the Mobo and CPU settings, still nothing.
Also, I’ve tried using a different monitor, still nothing.
Does anyone know what the problem might be?
Thank you.
Bu iyi bir soru mu?
Puan 0
15 Yorum
Hi @sabpan ,
Do you normally shutdown the PC or let it sleep or hibernate (if available)?
Have you checked Event Viewer for any errors etc that may give a clue as to what is happening?
Does this happen when the monitor is connected to the onboard graphics adapter? Remove the GPU card from the PC.
tarafından
Hi @jayeff,
1. Yes, I just shut down the PC. No sleep or Hibernate
2. The event viewer is full of Warnings such as:
WHEA-Logger with ID 17
and a few errors such as:
Msiinstaller, iD 11316
WLAN-Auto Config, iD 10000
Service Control Manager, iD 7043
Service Control Manager, iD 7000
I ve already searched solutions for a few of them but I dont know if they are related to the problem.
3.I have the monitor connected to the GPU HDMI port
If I plug it on the onboard graphics adapter, the monitor has no signal.
tarafından
any chance you have a spare gpu that you know works? I'm looking at your system to see if there might be an issue
also, have you tried using a different connection on the GPU? it looks like you have displayport and USB-C
also try moving the GPU to the other PCIe slot on your motherboard. looks like you have 2.
@sabpan
tarafından
@captainsnowball
Thanks for the reply,
First of all I have not a spare GPU. I'll try to find one. My monitor is a little bit old so it has not a usb-c port, but I can find an adapter and see if it works.
Finally, I have tried changing PCIe slot , no luck.
tarafından
I find it interesting that it worked for one month. is there anything you did during that month? (BIOS/UEFI flash or setting changes, unexpected shutdowns, programs) and just to double check, the display does not come on at all? or does it come on once windows boots?
it does seem to boot judging by the fact that you have to hold the power button (if it were stuck in POST it would shutdown without being held typically)
tarafından
10 tane daha yorum göster
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
The common cause is corruption of drivers. Much, much more common than any hardware defect.
This has worked a number of times for me:
  • Completely uninstall graphics drivers.
  • I use DDU (Display Driver Uninstaller) which has a mode for AMD or Nvidia drivers (Majorgeeks.com is a good download site).
  • Shut down and reboot. Re-install latest graphics driver.
Personally, I run Ccleaner and Advanced System Care to clean any “stray” settings that may have been corrupted. But DDU alone is probably fine.
Let us know how it goes.
For other readers. I have had this problem, especially, when I have switched graphics cards.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
Wouldn't it be less of a hassle to use SFC /scannow and DISM /Online /Cleanup-Image /Restorehealth?
https://docs.microsoft.com/en-us/windows...
@aactech
tarafından
Yes, you could do that. I just find graphics drivers corruption a very common cause of tough problems but do use the above method for more obscure problems.
tarafından
Yorum Ekle
In your event manager logs, I see a lot of errors mentioning vendor 10DE (Nvidia) and 144D (Samsung)
Try updating your graphics driver using through device manager, as well as updating your HD audio drivers, and M.2 drivers.
that should at least resolve the WHEA errors, which should cross that off the list of possible problems.
Puan 1
Yorum Ekle
Hi sender,
Have you tried to replaced your VGA? You may try to check also the VGA female connector in your PC. It may had worn out wires.
Puan 0
1 Yorum:
the GPU in question has no VGA. https://static.gigabyte.com/Product/3/67...
tarafından
Yorum Ekle
Yanıtını ekle
sabpan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 2,744
