Ana içeriğe geç
4 Kasım 2017'de satışa sunulmuştur. Model A1865, A1901. GSM ya da CDMA olarak 64 ya da 256 GB kapasitelerinde, Gümüş ya da Uzay Grisi renklerinde satılır. ("iPhone 10" olarak da telaffuz edilir.)
1199 Soru Tümünü görüntüle
iPhone X Boot loop after water damage
Hello guys. I have had my iPhone X for 2 years now and I have taken over 100 pictures underwater with no problem. Three days ago I dropped my iPhone in the bathtub for no more than 2 seconds and got it out. Feeling safe that the phone is waterproof I left it on the shelf and an hour later I looked at the phone at it was bootlooping and having all kinds of strange artifacts on the screen.
I took the sim tray out and left it next to a fan. On the other day the phone wasn’t turning on at all. I left it in a bag of rice for 2 days(I didn’t think it would help). I took it out 2 days later and the phone was showing that there was no battery and still had artifacts and screen flashes.
I removed the screen and tried to dry the phone with a heat gun. After that the screen was fixed and there were no more screen artifacts, but the phone is now bootlooping.(5 seconds apple logo, 5 seconds black screen) until the battery is empty and then it shows the no battery animation again. Any idea what I need to replace or do in order to get the phone to boot, or is the logic board fried ? Thank you.
Update (11/19/2019)
Hello guys. The phone is almost fixed. I cleaned the taptic engine connector and the phone booted. I have 2 remaining problems:
  1. The taptic engine makes very strange metal noises. Most likely it is damaged ?
  2. When heating the phone I have managed to melt the front camera and the infrared camera. All other sensors are ok and there is no error for face id. I know the front camera can be replaced without problems, but will replacing the infrared camera break Face ID ? I know the flood illuminator and the dot projector cannot be replaced, but what about the infrared camera ? Does it have a chip with logic board data ?
Bu iyi bir soru mu?
Puan 2
2 Yorum
How hot was the heat gun, and was the battery still installed when you heated it?
tarafından
@reedcrosby
Very hot and the battery was installed, but I never pointed the heat gun at the battery.
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Open charging flex and power on iPhone and check most have vibrator circuit issues.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
watch this video . will give u an idea how to fix that. https://youtu.be/BU95TBsJxM8 https://youtu.be/BU95TBsJxM8
Puan 1
Yorum Ekle
Hello I have the same problem.
totally you find a solution ??
Puan 0
Yorum Ekle
Yanıtını ekle
Nikola Hristov sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 884
