Ana içeriğe geç
16 Eylül 2016'da satışa sunulmuştur. Model 1660, 1778 GSM ya da CDMA olarak 32, 128 ya da 256 GB kapasitelerinde ve Altın Gülü, altın, gümüş, siyah ve simsiyah renklerinde satılır.
2265 Soru Tümünü görüntüle
iPhone 7 touch ID fail after battery change.
I changed the battery in my iPhone 7 with an IFIXIT kit yesterday. The repair went well except that the touch ID doesn’t register fingerprints anymore. The home button functions normally otherwise. I’ve removed and attached the screen several times now and can’t see any damage to the ribbon cables. I also disconnected and reconnected the battery.
Are there any suggestions for fixing the touch ID? I saw one similar question where the person bought a new screen and was successful. Is that the first or main solution, or are there any tests or other things to try?
Thank you for any suggestions.
John
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
If you were just changing the battery, and you didn’t unscrew the home button itself (which is very susceptible to nano-tears) then the *most likely* reason you lost Touch ID is from stress/rough handling of the flex on the screen that is the conduit for home button/touch id data. It is easy to tear or stretch that flex.
To rule that out, see if a new screen will solve. That would be your next step.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Thank you Jessa. Your advice seems reasonable. I certainly could have stretched the ribbon cable opening the phone. I can't see any kinks or tears, but I suppose the conductors are small and fragile enough to separate under the stress I caused opening my first waterproofed phone. I guess I'll decide if I want a new screen or want to type my pin. If I replace the screen, I'll note it here. (I enjoyed reading your "about." Good luck with your endeavors!)
tarafından
Yorum Ekle
Yanıtını ekle
jcs sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 99
