Ana içeriğe geç
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
Internal speakers not showing up or working...
Bought second hand iMac on fb market place knowing it needed a new hard drive, replaced it with an ssd as well as upgrading the ram to 16 gig, everything works perfectly except the speakers… they are defiantly connected and they do work as I get the startup “bong!” Every time I turn the computer on, but other than that there is absolutely no sound, ive tried reinstalling the os, also tried using with headphones in (no sound through headphones either) leading me to believe there is something wrong with the port that seems to make the computer think is has some other form of speaker connected even though it does not,
Can anyone help with this?! I’m not bothered about the headphone jack working but I would like to be able to use the internal speakers at least :)
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
2 Yorum
You could use a pair of bluetooth speakers or headphones in the meantime ;-}
tarafından
Same problem, clean jack not helps
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Often times the jack switches get messed up
You’ll need to inspect the contacts within the jack to see if they are working properly. I’ve seen the contact rotated as well as dirty.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
jack crowther sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 127
