Ana içeriğe geç
A programmable brewing machine by Keurig. This coffee maker uses K-Cup Pods and K-Carafe Pods to brew a variety of hot and cold drinks. Model Number: K2.0-400 Serial Number: 401.0200.1410931
63 Soru Tümünü görüntüle
What is this tiny silicon rubber part?
I was cleaning my K400 this morning and pulled out the pod holder and the tray below that. This part was in the tray (pen shown for scale). I would guess it goes over one of the needles? Which way is up?
Bu iyi bir soru mu?
Puan 2
15 Yorum
Hi, same exact thing happened to me today while cleaning my Keurig. Did anyone figure out where this tiny piece goes???
tarafından
Nope, I'm guessing it goes over on of the upper needles, but not sure which one or wich way up. I might just try all possibilities.
tarafından
Well, I was going to post a photo of where this goes (to answer my own question & whomever else may need this info as well), but I don’t seem to have the ability to attach a photo.
Simply put, it goes on the needle head that the coffee pod sits on. I believe this little silicone/rubber piece acts as a cushion, holding the coffee pod in place & preventing the grounds from coming out. Slip it on the “needle head” so that the larger end is on the bottom.
tarafından
Same problem a few days ago. Keurig sent me a replacement cup holder at no charge, priority mail (after trying to sell me a new unit). The piece slides over the bottom needle of the cup holder. The larger circle/end of the rubber sleeve was on top.
tarafından
Looks like bottom needle with the big end up! Thank you "Name"! If you would be so kind as to add your comment as an answer I'll accept it.
tarafından
10 tane daha yorum göster
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
I experienced the same issue recently. Keurig customer service could not provide an answer, because the model has been discontinued. They did, however, send me a replacement K-cup holder via priority mail. Upon my inspection of the new cup holder, I observed the silicone piece situated over the needle located inside and on the bottom of the cup holder. The larger circular end of this sleeve was closest to the top of the needle.
Bu yanıt yardımcı oldu mu?
Puan 4
4 Yorum:
Thank you! Same problem, this was a super easy fix now that I know where it goes. :)
tarafından
Thank you figured it out after reading your information you guys are awesome
tarafından
I appreciate that you shared this. I had it put back together in no time. ?
tarafından
Does anyone have a part number for this or where I can get a replacement? Thanks
tarafından
Yorum Ekle
thanks for the help !
here’s a picture of after replacing the silicon sleeve on the bottom needle
Puan 2
Yorum Ekle
Kevin Hollingshead  appears to be the seal around the puncture needle. Take a look on here How to open and clean Keurig Coffee Maker at Step 2. Different model same idea.
Puan 1
5 Yorum:
Thanks, Mr. O, but the bottom needle seems to be too short. But thanks for the indirect tip to find cleaning vids/guides. Keurigs parts support sucks. A nice exploded view would help.
tarafından
My kurig will not poke a large enough hole and water and grounds overflow! I have cleaned it and ordered a new pod holder/needle and still same issue???
tarafından
I had the problem with the bottom needle and overflow of the pod due to not letting the water back out. Putting the pod in place then removing and placing it in a different place and punching a second hole in the k-cup temporarily fixed it. A closer look and removing the silicon sleeve on the needle seems to have solved that problem. That little ‘sleeve’ is a very efficient stopper!!
tarafından
Yeah water was coming back up from the top. I've had this one for a few months with NO issues (previous v.2 lasted 6 years). I removed that silicone sleeve on the needle and it's working fine now...just wondering if this is OK???
tarafından
@rosannedobbs it will be okay. By removing the O-ring you just get the needle deeper into the cup. For as long as you do not get a leak or to much debris where the O-ring used to sit, you will be ok.
tarafından
Yorum Ekle
Yanıtını ekle
Kevin Hollingshead sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 112
Son 30 gün: 584
Her zaman: 32,209
