Ana içeriğe geç
Repair guides for the Surface Book 2 15", The 15 inch version of the hybrid laptop/tablet manufactured by Microsoft. This device was released in November 2017.
23 Soru Tümünü görüntüle
Can anyone identify these antennas attached to display?
I removed the screen from my SB2 to fix an issue. However once he screen was on the bench I noticed that there were still some thin metal strips that had remained on the screen when it was removed. The tabs that make connection to the mother board are ribbed so I cant salvage them. I need to know what they are for, if I’m going to damage a radio by turning on the device without them attached.
Bu iyi bir soru mu?
Puan 0
2 Yorum
Thanks, I guess the next question is does anyone know where I can get a replacement/equivalent?
tarafından
Did you eventually find the corresponding part? Do you have a part number with which to search for it?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Basically all wifi antennas, Book 2 uses 2x2 mimo configuration, there should be 2 feed points for signal and some other parts just for resonating, to improve reception.
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
Do you know of anywhere that can provide replacement ones?
tarafından
That's hard. The Surface parts market is very small and those non-critical parts are even harder to come by. Search by model number like "1793" (Book 2 15 inch i7) has worked best for me to find the parts.
tarafından
Yorum Ekle
Yanıtını ekle
E K sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 10
Her zaman: 184
