Ana içeriğe geç
The March 2015 update of Apple's 11" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
What screwdriver do I need to open the battery panel? MacBook Air 2015
I spilled a little vinegar on my laptop days ago. I’ve just got the right screwdriver to open the back of it but I’ve discovered that I need two different screwdrivers to open the battery panel. Where can I get this in stores! Please help! Thank you. MacBook Air 2015
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Here’s the iFixit guide you need to follow: MacBook Air 11" Early 2015 Battery Replacement
You need the following screw drivers:
Precision fixed blade screwdriver engineered by iFixit. Görseli
Ürün
T5 Torx Screwdriver
$5.49
Compatible with the type 5IPR fasteners used on MacBook Air, MacBook Pro Retina Display laptops, and Toshiba drives. Precision fixed blade screwdriver engineered by iFixit. Görseli
Ürün
P5 Pentalobe Screwdriver Retina MacBook Pro and Air
$5.99
Bu yanıt yardımcı oldu mu?
Puan 2
3 Yorum:
My laptop isn’t turning on. Do you think the batteries are just the problem? Where do I get new ones?
tarafından
Before you jump into getting a battery. How about doing some basic tests.
When you plug in your charger what color is the MagSafe plug Amber or Green?
If the charger is not lighting inspect the contacts for damage and clean the contacts if needed.
Is the charger the correct one for your system?
tarafından
The charger lights up when I plug it in. It turns from green to amber. I don’t want to start my laptop again because it shortens it. When I start it it turns on and then shuts down real quick. I can’t believe it’s not working. When I spilled a minuscule of liquid on it and wiped it up right away. I don’t see any corrosion inside nor any liquid. I don’t know what’s the problem. If you could please help me thank you
tarafından
Yorum Ekle
Yanıtını ekle
aimee sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 19
Son 30 gün: 75
Her zaman: 9,961
