Ana içeriğe geç
Chrysler, 2008 model yılı Town & Country aracını 2008 modeli olarak 16 Ağustos 2007'de satışa sundu.
My radiator plastic cracked
Can i fix the crack in my radiator (the plastic right above the top transmission/ac coolant lines) with j.b. weld? I have tried every bars leak they make. And 1 other kind of stop leak but they jus get blown out by the pressure.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
A new radiator is the only real solution.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Plastic welding is an option. Plastic welding follows the same basic principle as metal welding. Add material, apply heat, everything fuses together. With plastic welding, there are lots of different types of plastic. However, plastic welding in the auto industry has been a thing for some time, so it’s more likely you can have success. Nylon is the plastic I read about in use in radiators.
An airless plastic welder is little more than a soldering iron, but I have found advantages to them over a soldering iron. Mostly the tip is very large so heat can be applied over a large area.
Puan 1
Yorum Ekle
Yanıtını ekle
Shawn Patrick sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 693
