iMac LCD jumps from blue to black
This beautiful Intel based iMac 20” early 2009 at startup jumps to a blue screen with a lot of visual noise (just for a second) and then turns black and stays black.
I’ve checked the screen for image with a flashlight, no signs of a faint image.
I’ve disconnected all LCD cables (except for the temperature otherwise fans go crazy), hooked up an external screen through DP and the DELL external screen shows perfectly clear image.
The diagnostic LEDs are burning as follows: 1: green 2: green 3: off 4: green.
Inverter or screen, what do you think?
EDIT: upon closer look I find that LED 3 isn’t off but is actually missing! I believe this is the GPU indicator (someone confirm?) and since external screen shows image I believe it works.
Bu iyi bir soru mu?
4 Yorum
No diagnostic LED #3 Apple didn't populate it on this series.
Dan tarafından
I find it awesome that you know such a specific fact.
Sam tarafından
Using a flashlight held on the screen at a sharp angle do you see the faint image of your desktop?
Dan tarafından
Ah yes I forgot to mention in opening post. No sign of image with a flashlight either.
Sam tarafından
